Help Identifying Fordson parts
hymie2lt
Hello All
I have recently picked up a bunch of New parts from an old Ford tractor dealership that closed down in the 60s. I have a couple of parts that I cannot identify.
First...an hourmeter/Proofmeter...Part number E77 NE 9 in a FMC LTD Genuine Ford box.
Second...a rear lamp assembly...Part number E27N 13407 B.
I am thinking they are for an old Fordson tractor, but I cannot find any info on these numbers.
I have put photos in the "help Identify" gallery at left (cant get them to load here). Maybe someone out there can Identify them?
Thanks for any info you may have.
Wayne
Majorman
Thanks much for the info. May have a couple other parts, I may need some help on, a bit later.
Is the Fordson Super Major, a tractor model of its own too? I have a new gauge, valve springs and an injector tip, that is supposed to fit the Super Major... according to my research on the web.
Wayne
Yes, Super Majors came in 1960 with disc brakes, Draft control/Position control hydraulics and Differential lock, engine and gearbox were basically the same as the Major.
In 1963 the New Performance Super Major had more HP, different cylinder head and valve springs, drop control on the hydraulics, different gears in the gearbox and other minor changes. Production finished in around September 1964 when the Thousand Series Ford tractor were introduced.
