Help identifying MF50 model
Mobster
Hi, very new to this thread and hoping someone can help. I am looking at buying the tractor shown in these photos, and would like to get a manual but I can't seem to identify the model. There is a nameplate with serial number which suggests MF250, but there is an MF50 painted on the bonnet.
I particularly would like to know about the strange throttle, which seems to have left/right/centre pedals. What is the purpose? Also, I believe the shuttle lever is siezed onto its shaft and does not move. I assume from other tractors, that I should be able to simply move the shuttle lever to make the tractor drive forward and reversed?
It sure looks rough, but it starts and runs well. Apart from one leaky hose the hydraulics work well. I just can't get it to drive. I am hoping it is simply the lever needed to be freed up.
Any help/advise would be very welcome.
Welcome to the forums.
The tag with 250 in your pictures appears to be the tag for the model 250 loader, it is not the tractor's model/serial number tag. That is the reason the tractor has the 50 on the hood, which indicates a model 50 tractor. (The backhoe should have another tag for it as well). The tractor's tag may have been somewhere on the lower dash panel down around the shift levers, or on missing sheet metal.
Where in this wide world are you located? Things can vary depending on where units are built. You mentioned the 50 on the "bonnet" and the loader's tag indicates it was built in Australia, not to say they don't get shipped many other places.
I may be wrong, but I don't see a shuttle lever in your pictures. does the lever on the left side of transmission with linkage to the right side connect to the brakes? Parking brake lever? The pedal setup you mention may well be the shuttle shift for the transmission. One pedal is forward, one is reverse, center just throttle?
Hi, thanks for the reply.
I understood the lever on the right side of the seat was the shuttle shift? I am going there again in the morning so will take more photos.
I am in Adelaide, South Australia.
The lever might be, there are often differences based on where a unit is built. The US/North American unit parts books are often not totally correct for units built in Australia. There are some members here who live in your area that may weigh in when they see this thread.
Keep the pictures coming. Seeing where the lever connects may help.
Ok, successful day.
The lever I thought was the shuttle shift I think must be a diff lock. The funny three prong throttle pedal has a side lever which must actuate a clutch mechanism. So pressing the right side drives forward, and the left side drives reverse.
You were right about another label on the backhoe. Looks like it is MF50A.
