Help identifying tractor
BlueLB7
Hello all, new to the forum. I recently purchased a Ford industrial tractor and was told by the seller that it's a 1987 545A. I started doing some research and now believe I may have either a 340 or 340B. It has a 3 cylinder gas engine and 3 forward/2 reverse trans with hi/lo range. I'll post some pics, one of them being the ID label on the underside of the hood. Any help would be greatly appreciated.[/img:50d52fd861]
Having trouble uploading photos so here's the info on the ID tag on the hood:
Tractor # - C754755
Model - CU414K
Unit - 6B25B
Engine - 6A15A
Transmission - 6A19B
Rear Axle - 6A08B
Hydraulic pump - 6A13B
Hydraulic Lift - 6B04A
(quoted from post at 15:06:29 05/18/21) It's hard to tell without the photo.
Well, I just tried again to upload some pics and I guess I'm too new of a member and am not allowed to do that. I pretty much determined through other forums that I posted in that this is a Ford 545A that at some point had the original diesel engine swapped out for a Ford 3 cylinder gas engine from the 1970's. Also, the hood is from a 326B Ford ttactor so it's a bit of a Frankenstein tractor evidently.
CU414K is a 340B industrial with diesel engine, independent 540 pto and 6x4 manual reversing transmission
Unit # 6B25B is a build date of February 25, 1986 on day shift
If the tractor had been a 545A the model number would have started with DD4
(quoted from post at 06:34:31 05/19/21)
Look for numbers hand stamped into the clutch housing to the rear of the starter, see if they match the hood numbers, if not list those numbers
(quoted from post at 06:08:12 05/19/21)
I misspoke about the hood being from a 326B. It is from a 340B, but nothing else matches up. It's been a while and I've slept plenty of nights since I messed with all of this info so things got a little foggy.
I'll post the numbers that I got off of the rest of the tractor here in a little bit when I get a chance.
On flat spot behind starter:
LDd412k - model
7h20b - date code
C776392 - serial #
Transmission:
Right side - e2 nn-7006-ca
HH
6 k 28
Left side - 15 4 87
EONN4024CC
N w LH 2
Rear end:
Left side C5nn4013b
7f 1
Right side c5nn4013b
7e11
Right side of engine
T6. 06nn6015g
- the 0 may be a D?
Moddel # LDD412K, there shouldn't be a L
DD4 = 545A industrial
1 = Diesel engine of which someone has swapped a gas engine in
2 = trans 540 pto (not live)
K = 6x4 manual reversing trans
Unit # 7H20B = tractor was built Aug 20, 1987 on day shift
Serial # C776392 is for a 87 model tractor built in the US
