Help needed Farmall 95
rbel
little over 100 hours, boggs down pulling a 457 JD baler. CHanged both fuel fiters ran OK then started bogging down again noticed bubbles in clear inline fuel filter when it boggs down
Ideas?
Screen in bottom of tank? Pull fuel line off at 1st filter and shoot some air back into the fuel tank.Hook line back up and try it. If that helps it for a while, you may need to remove tank and clean. Also, does it have a water trap inline somewhere?
Plastic tank (I guess all the new ones are) Two filters, the inline before the fuel pump then the water sep/filter after the pump Have changed both. I wonder if the fuel cap may not be venting? My old 9N would do that until I got a new cap.
if this is a jx 95 tractor thr banjo fitting on the inlet side of the fuel filter will get plugged with debris from time to time.it is usually insects.remove fitting from line clean and you're ready to go.good luck fran
