Help needed please
gilbert680
Hi i have an international AW6 i went to start it the other day all i get is a big backfire through the exhaust can anyone tell me how to time the h4 magneto in, do i get the number one piston tdc and the pointer pointing at first notch on balancer then what do i do as Magneto is off the tractor. Thank you
Remove all the plugs to make it easier. Put a cotton ball in #1 cylinder spark plug hole. Hand crank, or fan crank the engine till the cotton
blows out. Put a plastic Drinking "soda" straw in the #1 spark plug hole. Turn the engine in Clockwise from front rotation untill the straw is
sticking out maximum. (you might need to shorten the straw some, or hold on to it.) now look at the timing marks, it will not be the first mark,
because that is advance, not TDC. Adjust the engine rotation to align that closest mark. Turn the mag so the rotor is pointing between The #2
plug tower, and the #1 plug tower. Basically straight up when the mag is as it would be mounted. Put the mag in place with the drive coupling
engaged. (it will be tilted toward the engine block) put in the retaining bolts, but not tight. Turn the mag slowly away from the engine until
the impulse coupling snaps. Lock it down right there. Best I have, Jim
(quoted from post at 17:57:32 06/10/20)
(quoted from post at 08:55:05 06/10/20) Except the mag is off the engine. Hi tried again today all I get is a loud bang through the exhaust here are some pictures and can anyone tell me what the mark is for on the rim of the H4 mag is it for the two cam gears as I had them out but I lined up the beveled tooth on the little gear with the R on the big gear
Might be one or two other things. Are the plugs wired like this: #1 is front. The order is 1342. Starting at the 1:30 position on the cap as 1,
going clockwise the bottom right cap tower goes to #3, then bottom left to #4, then top left #2.
The other issue could be a open (stuck or mis adjusted valve on one cylinder. Jim
I hope you got it working. I have a copy of an AW-6 parts catalogue, if you need some pages.
Not of use with your timing issue, but out of interest, was the ignition altered to your knowledge? I believe AW-6 tractors were fitted with a Lucas distributor at the factory, same as AM tractors and AOS-6 tractors. To be honest though, the H4 magneto is a better unit than the Lucas one.
SadFarmall
