Howdy, I've had my 48 (I think) 8n for a couple years and love it. But it's progressively getting harder to start - so I thought I'd convert to 12v (I'm aware of both sides positives/negatives). Consistent problem with the 6v - difficult start, would start sometimes after I crank for 10-15 mins. But killed a new battery after 1.5 years, not a cheap fix every couple years. Apart from the 12v conversion here's what I've done - New plugs, wires, points, and carb cleaned.
After converting to 12v I've (via a kit) replaced the generator with the alternator, put in new 12v coil, put a resister between the existing 8n ballast resistor and the coil, new 4g battery wires (switched to negative ground), and have re-cleaned the carb. I checked the gap on the point (reset to .015). Checked voltage to the coil when switch is on, at 10v. I checked resistance between original ballast resistor to the bottom of the coil - and it doesn't seem to be as much resistance as it should be (need to retest but it wasn't near the 4ohms needed (or so I've read). Still am not getting anything. Pulled plugs and was getting spark but not sure if is strong enough. I haven't done a compression check, but plenty of suction through the intake and finger over the plug hole seems to have enough pull. Any help/suggestions are welcome. What have I missed or overlooked?
BTW - love this forum and webpage. Have been following for awhile and love all of the advice people give. I think I might be an 8n'er for life. Love this little tractor, but need to get it running before the snow falls (in Iowa).
