John Diercks
Previous post: '48 8N, drove through gulley, tractor stopped in mid-gulley; first cranked, no fire; then nothing. Checked all connections, had battery checked per Dell's advice. All OK. Checked for spark; nothing. FINALLY figured out what is wrong, when I removed front-mount distributer...as axel pivoted as tractor moved through gulley, right sided of axel hit distributor nipple, knocking dist. cap and appearantly causing rotor to fall loose from cam. Now to get tractor moving again, I will jack up left front, place boards under l.f. wheel, replace dist. and hopefully drive off. BUT...how to fix? What is in need of R&R to keep axel from hitting the dist? I assume something is loose? Any advice??
