FordManiac
I’m trying to change out the starter but can’t figure out how to access the 3rd mounting bolt on the backside of the starter. Can someone help me with best way to do this?
(quoted from post at 08:31:14 05/20/18)
Ok got it. I ended up using a swivel knuckle as I couldn’t get a exact straight line on the bolt head. Anyway got it and thank you. So I replaced the starter but lights still only come on dash but doesn’t try to crank at all just like before. Battery is good. So now what all should I check? I really thought it was the starter as it was slipping bad and hard to crank every time. Had to keep coming on and off the key to get it to catch then eventually it would start. Then got to the point where the tractor doesn’t even try to turn over at all Only the lights on the dash would come on. Unfortunately with the new starter it’s still doing the same so there’s another issue somewhere. Thoughts? I put a new neutral start switch in several months ago so am thinking that might not be the issue so wasn’t going to check that first.
(quoted from post at 13:55:36 05/20/18)
Jump across from the start post on the starter to the battery post, make sure the tractor is in natural.
If it cranks ok the starter, battery and main cables are ok and the problem is in the key circuit.
A couple of problems I've had.
The key switch went bad on the mil's 5600 and it wouldn't crank over at times, finally stopped cranking over until I replaced the key switch.
The harness plug on my 4000SU wasn't getting good connection and the starter was jumping in and out making me think I had a bad starter solenoid.
(quoted from post at 11:26:59 05/20/18) Do you own a test light or a voltmeter? Of course the first thing to check is the condition of the battery, hook the voltmeter to the battery and see what you get. Leave the voltmeter on the battery and try to start and see if there is any change. Leave the negative lead of the voltmeter connected to the battery and now go to the ignition switch and see if you have voltage there. Then try starting it and see if the voltage is passing through the switch when you turn it. If it is then go to the neutral safety switch and ck if the voltage is passing through it when attempting to start while in neutral. If it is then you go to the starter solenoid. Ck for voltage at the battery cable at the solenoid first. If goo then go to the small terminal of the solenoid and see if there is voltage there when attempting to start.
Yes you will need to bleed the system if you remove the fuel filter on a diesel tractor.if you take the fuel filter out do you have to remove air from line to start tractor thanks Don i have the single filter
