Help on identifying my ford tractor please.
Rmiller123
I have typed in and searched around the internet to get any information on my recent ford tractor purchase. Was told it was a ford 9N. I looked for the serial # stamp on block and it does not start with 9N or 8N as stated in many on other forums. My stamp is 4-0-1035-A5AT.
I have another stamp right where the starter connects up to the block it is D268 then right below it it says 8N.
Stamp on rear axle is 9N4013B. If anyone could help me identify the year I would much appreciate the help. I need to figure it out so as to get some parts. My lower lift 3 point shaft has a leak and side arm bar needs to be replaced. Thank you
(quoted from post at 16:22:31 08/03/19) I have typed in and searched around the internet to get any information on my recent ford tractor purchase. Was told it was a ford 9N. I looked for the serial # stamp on block and it does not start with 9N or 8N as stated in many on other forums. My stamp is 4-0-1035-A5AT.
Probably a replacement engine and quite possibly a mutt. Post some pictures of the tractor - front, rear, and side views. Transmission (3 vs 4 speed) and brake pedal layout are main distinguishing feature between 9N and 8N.
TOH
The code near the starter, D268, is the date the block was cast. April 26, 1948. That would mean the engine either is on or came form a '48 8N.
I figured it is a mixture. There is stamps all over the rear axle and pto engage lever. Both of them are stamped 9N. The 8N Stamp was throwing me off and the serial # stamp on the block behind the filter.
(quoted from post at 19:04:04 08/03/19)
After 80 years engine serial numbers dont mean much. The tractor is fundamentally a 9N with farmerizations. For example it has an 8N starter with solenoid and modified wiring. Probably a few other oddities as well.
TOH
(quoted from post at 13:22:31 08/03/19) I have typed in and searched around the internet to get any information on my recent ford tractor purchase. Was told it was a ford 9N. I looked for the serial # stamp on block and it does not start with 9N or 8N as stated in many on other forums. My stamp is 4-0-1035-A5AT.
An 8N on the block would indicate it is an engine so your 9N or 2N was swapped out at some point. Does it have a 4-speed tranny? POSITION CONTROL? You can't go by part castings and their prefixes. If an original part carried the 9N prefix and didn't change with a 2N or 8N it would still carry the 9N part prefix. There are a few Hundred Series parts still with 9N part prefixes. Hydraulic pump hosing had casting code dates, but your 8N probably came with an 8N pump. As the late Delbert use to say, "...congratulating, you have bragging rights to a mutt!!!" Even so, don't put much into serial numbers. Unless you have a very early 9N or 8N worthy of complete restoration, don't sweat it. Concentrate on the important things like front or side mount distributor; Position Control; 6V with generator or 12V with alternator; 3 speed or 4 speed tranny. Don't pet the sweaty stuff...
Tim *PloughNman* Daley(MI)
I was more less wanting to get a year so that way I can start ordering parts for this tractor. I could care less about it being a mutt lol as I plan on using it. So long it does it's job I am fine with this tractor. I know I need the lower 3 point shafts and seeing different ones for sale is what started this post. I also will be needing to tear into the steering one of these days as there is play on the left side. Thanks everyone for the information. Really appreciate it.
(reply to post at 18:58:18 08/03
it is a 3 speed tranny and has a highway gear also. I read somewhere that the key ignition position also had a meaning to the year. Some were right side dash and mine is on the left side column. Its doesn't have the safety either for when you start it. Read an article that stated some had a safety device that made it to where you could only start the tractor in neutral. Mine does not have that set up.
Rmiller,Yes I noticed that from the pic you posted,that it had no safety thumb button.I would guess that it is a 1943 war model 2N with a 48 8N engine.Look at the front FORD badge on the hood and under the scripted FORD look for a small 2N stamped on the badge.
Sad thing is is there isn't a badge. One of the fenders and grill are off of another tractor. They both have a lighter grey texture to them. The area on the dash that ID tag is missing and the one under the seat is nothing but rust. It's a good ole tractor but is a mixture of multiple tractor parts lol.
In some cases they used the same part
for longer than just through the
Hundreds.
I helped a guy go through the front end
on about a 1988 4610 once. Replaced tie
rod ends, spindle bushings, thrust
bearings, etc.
The spindle bushngs are two different
sizes with the lower one significantly
larger than the upper. But the upper one
still calls for part # 2N3109.
That's 40+ years they used that same
part. Maybe longer.
Rear axle number is a casting number, as cast raised not 'stamped'... there is no serial number located under the seat where do you here that from??? Again, s/n don't mean much anyway. Accept you have a "mutt" and move on to important things.
Tim *PloughNman Daley(MI)
It's a late '43/early '44 2N with 8n engine swap and 8n paint. Parts get switched around all the time on these old
tractor.
