Help - PPG Base Codes - 730
old red guy
I posted on Paint & Body for codes and the Re.s I got was two No.s the PPG dealer said were a special mix and would not recomend me doing those. He gave me two for classic green (40249 & 47910) and yellow (41374 & 41680). Anybody know which would work . Thank You .
The green I used from PPG is 46180. I used DuPont for yellow as I never liked the offerings from PPG in yellow.
<img src="http://img.photobucket.com/albums/v16/Fboerger/70%20Diesel/Ltsidecrop.jpg">
<img src="http://img.photobucket.com/albums/v16/Fboerger/Paint%20Codes%20-%20Photos/70FinishedPaint.jpg">
F-I-T I thought the green you used was code 46180? That is the code I shot on mine and i thought i arrived at that after searching through some of your older posts.
Thanks for catching that! I had a typo, so I changed it in the other reply, too. Yes, it is 46180, and that paint was PPG DAR Acrylic Enamel, color sanded, then clear coated.
Recently, I have been using DuPont Ful-Thane urethane, code 262 for the green, and 263 for the yellow. Those codes are good for DuPont for any chemistry you buy from them. Here is a pedal tractor with the green (only the seat is DuPont yellow as the wheels are as they came in power coat). I didn't go to too much trouble on it since it will likely catch the wrath of the young grandsons.
<img src="http://img.photobucket.com/albums/v16/Fboerger/1Forum%20Postings/IMGP1338.jpg">
These are probably the two codes that your supplier said to stay away from (43817 green and 81512 yellow) You ARE the customer the last I knew! These two have the same exact paint on them. As you can see different cameras and different background contrast will make ten tractors look like ten different codes , BUT , put them all side by side in the show and you probably won't tell the difference. FIT and others codes (inc mine) are all correct as you will get. I'm sure the paint from JD is right out of the original batches from the '40,s and '50,s so it must be the best. (yea , right) Do your homework , you have some good choices , pick one and commit to it and move forward. (and stop listening to your counter-man / boy / or whatever!)
