I recently purchased a Ford industrial tractor and was told by the seller that it's a 1987 545A. Well, I started doing some research and now believe I may have a 340 of some sort. It has a 3 cylinder gas engine and 3 forward/2 reverse trans with hi/lo range. According to Tractordata.com, there was no gas engine even offered for the 545A. I'd really like to find out more about this machine so that I can get a shop manual for it and know exactly what I have. Any info or advice about this machine would be much appreciated. Thanks in advance for any feedback! Here are the numbers on the ID tag on the hood:
Tractor number: C754755
Model: CU414K
Unit: 6B25B
Engine 6A15A
Transmission: 6A19B
Rear Axle: 6A08B
Hyd Pump: 6A13B
Hyd Lift: 6B04a
Model: CU414K
Unit: 6B25B
Engine 6A15A
Transmission: 6A19B
Rear Axle: 6A08B
Hyd Pump: 6A13B
Hyd Lift: 6B04a
