AnvilheadTX
What a frustrating day. Last weekend I hosed off the 8N (to prepare for leaking governor work)and it ran as if maybe the points were wet or something afterword. When I started it today, it still ran sluggish. I repaired the oil leak in the governor and thought all it would take was a little ideling to get her running like normal. When I engaged the PTO in first gear it was real sluggish and bogged down on very light grass. I disengaged the PTO and realized the tractor was sluggish in all gears and when put in 4th (w/o PTO) it stalls with a decent size black cloud spitting out the exhaust. Also, the tractor sounds as if there is popping coming out of the exhaust when the throttle is turned high and there has been a few backfires (never before). At idle, the tractor sounds excellent. I spent the day repalcing the points, condensor and rotor - thinking all I needed was a little tune up. No dice, the light popping, occasional backfore when starting, slugish performance and stalling in 4th contiues.
Any suggestions, my itchy-twitcy fingers are moving towards the carb? Also, I did have a good oil leak out of the govenor and I have been putting a lot of oil in the tractor. Can I have too much oil causing poor performance? When the tractor is at full throttle, the oil pressure shows above 50?
The tractor is a front mounted machine. Also, no blow-by has been noticed and no weird noises can be heard around the block. In low idle, the tractor sounds very good.
Any input would be appreciated.
