Jon Decker
I have been using my 52" 8n for backblade snow plowing. The other day, after lowering the backblade, the lift arms just stopped working out of nowhere. Prior to this, the hydraulics have been strong (I used a 3-pint bale spear and moved over 300 round bales this last summer) and never exhibited any knocking under load.
I have checked the obvious - fluid level, PTO is spinning, etc.
I have removed the right inspection cover. There is plenty of hydraulic fluid (it was actually overfilled and I drained it to the lower inspection plate bolt hole). The fluid is a little dirty, but other than that it looked ok.
With the engine running, and the touch control lever to the full up position, there is no fluid raining from the top, so the piston above appears to be fine. I can see a little turbulance in the fluid in the rear area (swirling up from behind the differential), and the fluid "glopping" up and down towards the front with the pto engaged and the engine running. I"m not sure what is normal to look for here...
The Touch control linkage moves both up/down and front/back when the touch control lever is moved up and down. Again, I don"t know what is normal to look for here either. The rod looks slightly bent to the rear, but I"m guessing thats normal.
If it would be of any help, and can get some video of what it looks like in the inspection cover while the engine is running and the PTO engaged.
Any help is appreciated!
