Help with a IH 660
ghunziker
Are the hyd/tran and the power steering reservoir the same location on a IH 660? Where on the tractor are they filled? I know probably a silly question but would appreciate the help. Thanks.
yes its all the same oil from the trans and diff. to the right of the gear shift is the same plate , remove it and fill there. the oil check plug is on the left by the clutch rod. the oil filters are on the right side behind that plate and the ps has an extra pump behind the main pump on the left side.
Upvote 0
