Help with Carb Bowl
there is only one screw for the float. you need a big screwdriver to totally fill the slot and down pressure while turning it or trying to.
do not slip the screwdriver or the brass will break off. i have had tight ones but they come out.
post that in a picture. i have never saw a float in them carbs with two screws. its a screw with a pivot pin that the float pivots on.
There u go. Nothing saying u need to remove them both.
Get a good screwdriver and eat ur spinach and one will
come out. BUT use a small punch the same size as the
screw head and give it a love tap first.
jd2cyl1943 Clamp bowl in vise and use an Impact screwdriver. Lynn
https://www.amazon.com/TEKTON-2905-8-Inch-Manual-7-Piece/dp/B000NPPATS
