help with carburetor ID
esva 8N
I have a 1974 2000 3 cyl gas. Getting poor gas flow out of the carb bottom after a couple minutes running but good going into it so I'm thinking it's time for a cleaning and maybe a
rebuild. Tried the gentle tapping with a hammer handle and that doesn't help so I don't think it's just a stuck float. Even if that does turn out to be the problem i'll still need to get in
there to clean it up and perhaps install a new float.
My problem is I can't identify the exact carb model I have. I pulled it off and it is a zenith proudly made in the usa as stated on the side, but for the life of me I can't see any other info on
what exactly it is. I haven't opened it up yet so maybe there is some info inside but in any case, does anybody have any useful info? I haven't done any google research yet so if it's
something easy such as they only made one model I apologize for not doing my homework first. Thanks.
The original carb for a 3 cylinder 2000 would have been a Holley. But after a certain point Ford spec'd a Zenith as the replacement if the carb ever needed to be replaced. The Ford part number for the Zenith replacement carb is E1NN9510DA, but I couldn't tell you what Zenith model number that might be. There are probably a couple of different Zenith models that would work, so yours may be a different one than the one that Ford originally spec'd for the replacement to the Holley.
Thanks, that helps a lot. It looks like the same rebuild kit works for a bunch of the zenith's so the one I ordered should work. Thanks again for the quick help!
