Help with ford 1720
Metheds21
Hello I was hoping I could get some help from some experienced users I replaced some seals on my tractor's front end and I'm wondering how much oil to put in the final reduction gears and the front axle I have the manual but it appears to be way off i olny got 1.5 quarts in the reduction gear but it calls for 2.6 us for example same with the front axle front axle has a dipstick BUT do I check with it screwed in or not? It would make a quarts difference if its checked without screwing in
Not a Ford but the Front axle on our JD 750 you check oil level with the dipstick resting on the threads and NOT screwed in. Neighbors Kubota is the same way. Generally things with screw in dipsticks seem to be checked without them being screwed in.
