Help with ID, and part #
eco88
Hello,
I just picked up a diesel case 530 backhoe. The clutch is completely gone and needs to be replaced (before I start working on the rest of the hoe).
It's my first backhoe, and also first time working on a clutch, so I was wondering if anyone could help me ID the year/model of the backhoe, and/or part number for the clutch required.
I have looked at the parts and have noticed that there are few different versions of the clutches - not sure which one I need.
There are no serial numbers aside from the one on the frame. I have attached few pictures of it.
Thank you.
The serial number in the pic is for a model 32 hoe. My backhoe loader, has a plate on the boom for the
hoe, a plate on the loader arms for that and than an ID plate on the left side of the instrument panel
for the tractor. (facing the left side, on the tin surround)
(quoted from post at 11:45:10 06/06/17) The serial number in the pic is for a model 32 hoe. My backhoe loader, has a plate on the boom for the
Thank you for the replies. I do think it is a CK.
Unfortunately there aren't many identifying numbers left on it anymore (looks like it's been re painted a couple of times in the past, and most tags/engravings are missing)
Here is the other side
When I bought a 580CK all I found of the tractor. engine and loader tags were either rivits or holes. The tag was still on the hoe but painted over. I contacted Rich Tworek (since retired) at CNH with that number and he was able to tell me when the hoe was built (1967). I have assumed that was the same as the year my tractor was built. There is someone else now doing his job at CNH and I do not have her info at hand.
Bryce
the backhoe may have been built in 67 but that tractor is 1965 or 1964 as they quit making the 530CK (and yes that is what it at the end of 1965 , it then became the 580CK, with the steering style you have it will be a 64 or 65 model
cnt
Thank you everyone for the input so far.
So I'm going to go with 64/65 for now.
Btw I found the clutch; the part # is: 110813A1
Tom, my 580CK has a #33 hoe with s/n 4142456 and Rich said it is a 1967 build. I assumed the 580CK is the same year build.
Bryce
