Help with onan
Khemo
Hey guys, I'm new to the Forums so I apologize if I'm posting in the wrong place. But if recently bought two linamar zx390 engines, one runs perfectly but the second is missing the carburetor and breather box. I found a new carburetor but the cheapest is over $200 and I cant find a carb kit to rebuild it later. Is it possible to put a more common carb on this engine. I know if I replace the carb I'll need to make an adapter for the new carb. But I'm unsure what carb I'd use. I'm open for any help and advice.
Yeah a parts engine would be nice to have.
But what do you think would be best if the
carb for the running engine goes bad.
It's rare for a working carb to go bad beyond repair.
Even if you can't find a kit they can usually be eased apart and cleaned if needed. The worst thing for them is sitting with ethanol gas in the bowl, or water contamination.
I don't know what the carb looks like on that engine, but if you do need to substitute a different carb, there will likely be a name brand on it, start there looking at pictures, try to get as close as possible to the original dimensions and match the displacement/HP as close as possible. Pay attention to the fuel fitting location, choke linkage, and throttle linkage. Throttle linkage is very important on a governed engine, it must match the travel and operating direction of the existing governor closely.
Before investing in anything for the other engine, might switch the carb off the running engine to see if it will run and how it sounds.
goes bad? it wont spoil, they do require a cleaning at times. so big deal if you cant get a gasket make one. I am sure that carb will out last that engine. keep the fuel filter replaced as needed, use clean gas and don't store for long periods with out draining the gas.
I don't know what the Onan equivalent to that engine would be, but if you can figure it out, there' lots of generic (chinese) Onan carbs on fleaby for $50, give or take.
For the fourth time. That is the same engine as the Onan P218. Service manual is 965-0762. You can download it at
Smokstak manual section. All free.I will need to look up the parts manual
