Help with part numbers
JBart
I saw on here a couple weeks ago, someone had posted Napa part numbers for a Ford 8N and I can't seem to find the post.
I was wondering if someone could help me out finding the part numbers for my 1952 8N side mount distributor.
Points
Condenser
Rotor
Cap
Thanks so much
Points: NAPA Heavy Duty #CS 753
Blue Streak #FD-8081X
Condenser: NAPA STD. # FD-75
Blue Streak #75X
Ignition Coil 6 volt IC7
Plugs Autolite #437
Except for maybe the plugs and my 12 volt coil, are these distributor part numbers applicable to the NAA as well?
All those part numbers do apply to the NAA. Same Autolite 437 plugs.
For a 12 volt coil that does not require an external resistor, NAPA# IC14 or IC14SB.
Distributor cap for your NAA= NAPA#: FA352
Rotor button for your NAA= NAPA#: FA67
...and IMHO...if your spark plug wires are not real wire conductors, go ahead and replace them. You can get real wire kits at NAPA or any other parts house and make up your own set.
