Help with WD45 diff tranny gasket replace
I posted a few months ago about my 1955 wd45 having a gear oil leak at the differental/tanny connection area. Not sure what I was going to do at the time, but now have decided to pull the diff and tranny apart and replace the gasket. I have removed the back tires, the drawbar, battery and box, disconnected the brake lines, hand clutch and various other small items that would prohibit the separation-haven't disconnected the steering wheel mount, but it looks as if I need to as well.
My question is, what is the best way to pull the diff and tanny apart. I would like to attack it from the back end-diff end. If I pull the two apart, I assume there will be a shaft, will any thing be falling off the shaft as I'm pulling it out?
I have a cherry picker, jack stands, and a knowledgeable helper-I'm not that mechanical.
Any suggestions and help would be appreciated. I tend to keep this tractor in fairly decent shape and working order, this is driving me crazy until I get it fixed.
Get an I&T AC 11 service manual. In it you"ll find pics of separating the tractor, using two long alignment bolts. Don"t need to remove the wheels, etc. If you"re just replacing the gasket, you can pull the tractor apart an inch or so, cut the gasket at the top, and slip it around the shaft. Gasket compound should seal it at the top.
