Bspauld
I have a New Holland TC40DA with weak hydraulics, After using it a little it loses a lot of power, I changed the filter and that didnt help, I hate to think I have to take it in to split it and a new pump, I am hoping someone has a cheaper solution . Thanks in advance
The loader, I was using the forks and couldnt pick up much of a load, so a small Case skid steer used my forks and lifted it with ease.
Check your pressure and see if it's what it should be in the manual.. There is a lot of differences between loaders on different tractors. A bigger cylinder and more pressure makes a big difference. The loads a little skid steer can handle is amazing.
Look on the deverture block where the loader hoses plug into. If there's a slot head screw make sure it's turned on.On the older blocks all the way right is on.
Its a factory loader, but I will check the pressure and also make sure the deverter valve is right to, Thanks for the advice, I just got amanual
Bspauld
Have you checked/cleaned hyd oil strainer(encircled in blue)? Have you checked hyd oil level so you know it's at full mark?
