Hello bmell…, welcome to YT. For one that is not a model number, that is a serial number. Often through time and exposure to sun light all the printed/painted on info on serial numbers plate is gone leaving only the SN stamping. IH used the same serial numbers for multiple models. I don’t have the time to sort through multiple lists to report to you which possible models you may have. Do you have a smart phone? Take a photo of the whole side of the tractor, then to navigate to your post on YT on the web. Click the “Attach files” and select the location your photos are stored.(on an iPhone it is called the “Photo library”) Select the photos you took click “Add” (again this is the command on an iPhone). This should post your pictures.
