montytx
thanks everyone for helping me before. after a fer hours work i got it running very good. now im not sure what i have. the motor is a z120a. also i cant find the date anywhere on it. the only number on the casting is a 2 and thats it. ive taken some pics of the carb and casting and motor to see if that helps. the carb looks diferent from all the new ones ive seen for sale. thanks everyone with the help
I can only say for sure that your engine is from a TO20....I'm a bettin the tractor is just that. Your carb DOES look quite a bid different. does is say Marvil anywhere on it?
I may be from an earlier ford N series? I have had a few tractors with a Carter carburater and don't think that what they looked like either.
looks like my te2o carb,i used a farm all rebuild kit.my fergie is a 48, farmall a kit was for a 47,burkes hardware in conquest,n.y.usa
look on the front of the Axle housings just behind the heavy brake rods, there should be a casting date....John
what is the difference in a to20 and te20. the serial # plate is worn bad but i know it says made in england.
