Ken Christopherson
Hello all. Well, I'll cut right to the chase. A friend of mine has been working on troubleshooting his Super M for quite some time. Originally they pulled the head to fix a blown head gasket and a crack in the head. Ended up being a badly cracked head, and had to obtain a replacement. that was sent off to the machine shop, reworked, and reinstalled. Somewhere in the process of getting it running, they messed with the distributor timing. Couldn't get it right. They had it running, but couldn't get any power out of it. Carburetor is a complete fresh overhaul, so it isn't the carburetor. They thought it then may be valve lash. Adjusted the tappets, still didn't work. I mentioned that an issue that I had run into with an F20 might be solidified sludge in the cam followers/lifters. I recommended he pull the side cover and at least have a look at the lifters to see if there was a large amount of sludge that was throwing off his valve adjustment. In order to do this, though, he had to pull the live hyd pump and did NOT make note of the lag angle when he removed it... SO, the big question is. When he reinstalled the hyd pump, there is no telling if he is one or two teeth off. Something you think he would be able to adjust with rotation of the distributor... He claimed there were no timing marks on the drive gear (not that it would matter without having the front cover off). SO... I recommended he pull a fresh, hot mag off of another tractor and replace the distributor with it just to rule out the distributor and coil... BUT, without knowing whether or not the pump drive is in time with the engine, there is no guarantee that will work.
I know this sounds like a jumbled mess, but I am just trying to help him diagnose and fix the problem over the phone. I feel bad for the young man, as he has been trying to get this thing going right for a couple years. Many of you may have seen him on YouTube - This Old Farm is his channel name (link below). The video I have enclosed has the tractor running well, but it didn't last long. He is again suffering from no power. Will barely move itself in low gear or reverse.
At this point, I feel like we should pull the radiator, bolster, crank pulley, and timing cover... Get everything right as far as gear timing goes, double check valve lash, and then throw a mag on it just to see if it fires, runs, and has power like it should.
On a rare occasion, I have seen distributor gears spin on the distributor shaft... Causing the timing to slowly slip... Could be a coil issue, too? I don't know. Just at a loss for the poor kid. Looking for some insight.
This Old Farms Super M
