Hercules NXB Motor
edhughes
I have a JD L with a Hercules NXB motor. Recently started spitting oil from the front of the motor. I cannot determine exact location but suspect front engine seal. Are there replacement seals avaiable and how dificult of a job is it to replace the seal. Should I try a seal additive product with hopes this may cure my problem.
I can't diagnose the source of your leak from here, but it it's really the front crankshaft seal, it's still available from DEERE, #AL2653T.
Or, if you prefer aftermarket, check out the link below.
SKF/CR
