nh stump jumper
I picked up a Hesston 1010 haybine on a local auction knowing that it needed quite a bit of work. I have more time than money right now so I figured it would be a good project. It's been worked hard and not cared for very well but it fit the budget.
The pitman has broken and been welded several times. The reel center tube is cracked and will need welding or more likely replacing.
I have a PT7 in good shape except for the broken metal roller, for a parts machine. I also have access locally to a couple of PT10's
It looks to me like the pitman, bell crank and cutter head are the same on all three machines. The parts catalog says they take the same cutter head and bar.
Anyone ever used PT10 parts to repair a 1010? Any problem areas to watch for on the 1010 besides the usual bearings and timing issues?
