Also, I don't know how much experience you have with your particular haybine. I've run two Hesstons for a few years now...1014 drive chatters in hay. Have changed knife ,guards and associated bearings. Checked and aligned by manual
Half swaybar? That's a new one. I'm familiar with the 1070, 1090 and such... I wonder if the 1014 is different.Does that have a half sway bar like the 1120 had? The bearings inside of that will cause it to hammer if there's any slop in them. The big nut on the back of the bell crank is tight for sure?
I don't know. I had a 1010 hydraswing and an 1120. The half sway bar runs the knife off the bell crank. It attaches up at the top of the machine and pivots there. The bell crank sits back in it.Also, I don't know how much experience you have with your particular haybine. I've run two Hesstons for a few years now...
And I notice two different situations:
When everything is running well...
the chatter is audible in light, thin hay. When I'm going along in thick growth, it sounds quiet.
When there is a bearing or something loose...
There is still chatter in light, thin hay... but it gets louder in thick growth.
I tried to find parts diagrams online... Agco's website has abandoned the Hesston line.I don't know. I had a 1010 hydraswing and an 1120. The half sway bar runs the knife off the bell crank. It attaches up at the top of the machine and pivots there. The bell crank sits back in it.
It's on there. You must not be looking in the right place. 1014 center pivot, right? It doesn't have the half sway bar. The drive lays horizontal on those.I tried to find parts diagrams online... Agco's website has abandoned the Hesston line.
OK... if the drive lays horizontally; then it's different than the 1070, 1071, 1090 and 1091.It's on there. You must not be looking in the right place. 1014 center pivot, right? It doesn't have the half sway bar. The drive lays horizontal on those.
Ya, when you get to that site, click "Parts Book". Then where it says Model Vin Browse , click Browse. Now click Select Brand and it's there.OK... if the drive lays horizontally; then it's different than the 1070, 1071, 1090 and 1091.
I'm going to back out of this thread, except to ask... what website?
Here was my result from parts.agco.com.us...
Yup... found it. It loads about as fast as loading a dumptruck with a thimble... but it's there. Thanks. That's a great resource. I've been stumped on some of this since the "local" (about an hour away) dealer sold out.Ya, when you get to that site, click "Parts Book". Then where it says Model Vin Browse , click Browse. Now click Select Brand and it's there.
My 1010 didn't like fine grasses either. The 1120 with the half sway bar was a vast improvement.Changed pitman bearings several times. Even checked to see if there was special bearings. Castle nut on bearing never stays tight. If you overtighten knocks out bearing. Has broke metal where pitman mounts several times. Saw a picture of another 1014 with same breaks. Had a 14 ft 1014 and it never had this problem. Cuts alfalfa easy but ehen it sees fine hay it starts chattering like my dad used to say "loading the knife". Not like it is a heavy crop. Is poor.
Know the twin knife ones were better. My 14 ft cut better than this 12. Was mint when I bought it. Agco parts books don't show original bearing part number. Knife head ball is worn a bit. Cuts and quiet until sees praire grass. Even at creeping speed pounds.My 1010 didn't like fine grasses either. The 1120 with the half sway bar was a vast improvement.
