Hesston 1320 Discbine Leaking Problem
Reid1650
Leaks out of the top of the idler gear bolts. How do i get it to stop? Ive tried gasket maker snd it doesnt work. JB Weld? Im out of ideas. Thanks
use agco flange sealant it comes in a squeeze tube its about 20 dallers a tube. clean the surface good with brake cleaner before u apply it. its made to work for sealing with no gasket. if u need the part number i can get it monday when i go to work
not the same thing the agco sealer drys when there is an absence of air . ive used it to seal halfs of tractor rearend together works way better than ultra black
