Hesston 260 swather.....
banjoman09
Maybe not the right Forum but I need help- trying to replace the "steering belts" on my dads old Hesston 260 swather- no fun; been on it three days and still dont have it apart; I have the book but it is little help; anyone every had this experience? I hope not! I have the new belts but cant even get the old ones off...they are junk; what a nightmare! Thanks.
I had a 280 Hesston, hated that thing. The belts do come off but you have to dismantle half the machine to get them off. Take pictures while taking it apart so you remember how to put it back together.
I'd take the cell phone and take pictures of each and every pulley, roller, chain, pivot, etc... Probably can't have too many, and you can delete them as soon as you're thru.
I have had a 310 for 50 years and changing those steering belts is a much dreaded every 10-12 year job that I have yet to do this fall so that I am ready to go next summer. At my age this is probably the last time I will have to do it.
On the 310 it is fairly straightforward but time consuming; it generally spoils a day. I start by loosening the main (vari-drive) and reverse belts, then remove the hydraulic pump and unbolt the bearing housing holding that end of the reverse/header drive shaft. Next remove the bearing housing at the outside end of the main drive shaft (the one with the large vari-drive peully on it). Then continue to dismantle the battery box, sheetmetal and related bracing that carry those bearings mentioned above to a point that you can remove the vari-drive and reverse belts and you are 75% there.
As Jim said, it's easiest to simply cut the old steering belts off.
Threading the new belts in over the remaining shafts and pulleys is a challenge but imminently doable. Where you will get stalled is in getting them into their final position. Although it may seem impossible, if you twist one side of each belt 90 degrees they will pass up through the gap between those big final steering pulleys. The final drive shafts have a 3/4" gap between them which is why one must twist the 7/8" belts to get them through.
Thats the best answer I have had...there is one old belt still on there and I want to take it off- not cut it- so I see how to put
on new ones; I have the other belts off and bearings; im hung up on linkage and other shafts. not getting it. Thank you:)
I'm going from an old guys memory so I may have missed a step or two but try taking the old belt off the top most pulleys then through the gap between the final drives (old one should go through fairly easy) then thread out over reverse and main drive shafts.
I am on my way out the door for an appointment in town but when I get back I'll go down to the machine shed and have a look at mine to refresh my tired, feeble, senile old memory; Ill check back later.
Ok, pics aren't the best but maybe they will help. To remove the belt you have left in place; assuming you have removed the belt guide in the first pic and the idler pulleys at the top (pic 2), start removing the belt by lifting/pushing it up (from the bottom) between the final drive pulleys (pic 3). Once you have done that it is a simple matter of passing it to the front of the idler pulley tubes and threading it over the main drive shaft and then the reverse shaft.
Install is reverse of above; thread belt(s), one at a time, over reverse and main drive shafts then DOWN between the final drive pulleys.
