Hesston 4590 Feed
kevin2k10
I have a hesston 4590 but when you feed hay into the pick up it mashed hay in under the augers. is there an adjustment to change that or is that how it is supposed to be?
I have a 4590 and have had that happen before. There is a mention in the manual about pick up auger strippers, it is a optional piece of equipment and keeps the hay from wrapping around the auger, this is most likely what is happening. If the hay is feeding ok and you are not clogging I would not worry about it too much except to occassionally stop and clear hay caught behind the auger. It is most likely to happen in stalky type hay.Check to make sure your auger is not bent, I had the auger angle bend back where the sprocket drive is once.
