hesston 5540 roundbaler
rust-o
I have the opportunity to get a hesston 5540 round Baler from a local farmer for $ 1000. Thing is it has sat in the shed since they stopped making hay a number of years back. (Maybe 10?) And it has a 2foot bale in the chamber. Should I run from this as things are probably stretched out or is it not a big deal. Other things I should look for? Are these balers any good? I'm only doing 50 to 100 bales a year...
Around here, you can get an similar baler for the same money, but one you won't spend months and hundreds of dollars (at least) fixing. It's not even worth looking at, IMO.
We got one that works, and we can't sell it (everyone wants balers with net wrap), if you were in central Texas we would sell it to you, and show you how to run it which isn't difficult.
If there was nothing wrong when he parked
it...yes. My first baler was a hesston
5545. It is a simple baler that did the
job. Bales were decently tight. I baled
as many as 700 bales in a year, but
mostly 2-300. I paid 4500 for mine when
it was 20 years old. It was well
maintained. For a grand....I'd do it four
sure. You can call me if you want more
info. Jh
1000$ for a baler thats been sitting outside with half a bale for at least 10 years? It ll likely need that much more in belts and bearings, maybe more. I don t see how its even worth scrap price.
That does make a difference. At least there s a chance all the belts aren t shot. They still could be, but if it sat outside it would be almost certain. I d still pass personally. You can buy a baler thats ready to go for about the same money. But thats here.
Your area may not have as many used balers, around here they re everywhere.
Ours had been parked in a barn for years. We did use it 3 years ago to make 20 bales, just greased it, checked it over, baled the hay, put it back in the barn, it worked flawlessly. We can't get $1500 for it, and you could put it to work right away.
