Hesston 6600 swather
Patmf 285
Just bought a hesston 6600 swather, in real good condition. Just wondering about the power to the head. It all is run by hydraulics. Problem is head runs at good fast speed until you start to cut then slows down to about half speed. Turning around at end of field, head speeds back up again until you start cutting. Would rebuilding pump and motor help or is this just the way these systems work?
It"s the pump or motor going out or both. We bought one used years ago and the NH dealer then sold it to us said it was warrantied and the motor had been rebuilt but they never could get it right and wound up putting a new one on it. Find a good hydraulic mechanic at a Agco or Case IH dealer with Hesston experience.
Anything more than a 5% slowdown under reasonable load indicates a problem. A quick check would be to have a flow meter installed in the case drain line of the motor. When everything is in good shape, you should not see more than 1/2 to maybe 1 GPM of flow. If this increases to more than this under load, the motor has a problem. If the case flow remains the same when the header slows down, the issue is most likely in the pump.
Another quick and easy check would be to measure the pressure in the drive loop with the header locked up and the pump going over relief. If the relief valve is leaking, you will not be able to build the specification pressure. (I'm not sure what this is for a 6600, probably in the 3500psi range but your dealer would be able to tell you for sure.) If the pump is just leaky from being worn out, it would probably still be able to develop full pressure; just the flow would be reduced.
