Hey 01BIRDDOG
howdy1960
As you requested.....
There are 2 sets of about 50lbs each (I'm guessing as not checked on scale) on each side.
Boy these are nice and i'm a sucker for wheel weights. What were these designed for in the early 9 and 8N tractors. I can see they appear to fit perfect. Thanks for photo.
And the bolt heads are installed backwards, right? Meaning the head of the bolt is inside the rim. And the nut, a lock washer & what looks to be a huge flat washer on the outside. Right?
I've got a set & just never got past trying to figure out how to physically get them mounted w/o losing fingers or toes!
My setup might be differant than yours but here's how mine are mounted.
Bolt head inside rim hoop thru rim hat(?), nutted, weights, a couple good washers, lock washer and finally nutted tightly.
I started with putting bottom pair on then top pair. HTH.
