Hey Grandpa Love
VACLee
Does any of your Cubs have the bracket on the rockshaft for the assist spring used with the one point hitch? I need the dimensions so I can add the bracket to mine.
Don't have any with a one point hitch. Got one with a hand lift. Will send pictures shortly to see if it will work
I have the spring, the rod, and the rear bracket. I need to add the arm to the front rockshaft at the hydraulic control unit. It is about 90 degrees back from the arm that the rear lift rod attaches to. No problem making it just need the dimensions and accurate degree of angle from the arm for the rear lift. Was thinking that the later models may have the arm on them even if they did not have the one point. That way the hitch could be changed out without disassembling the hydraulic control unit.
These parts??
That's what I am looking for. I need the dimensions of the arm and I can add it to mine. Also approximate angle in relation to the regular lift arm. Thanks.
I found that the rock shaft for a Cub with Fast-Hitch is larger in diameter than one for a Cub without Fast-Hitch, and therefor requires different saddles where it mounts to the hydraulic unit. The arm I think you are asking about could be welded on but the shaft might not be strong enough.
