Hey Thurlow!
Bill(Wis)
Did you know, on modern view, you and I are classified as "Tractor Expert". Buickanddeere is "Tractor Guru". What do you think about that?
Yes, well to carry that a step or two forward, the term gu, meaning "darkness" coupled with ru, meaning "light" in the same word effectively means "one who leads from the darkness of ignorance to the light of knowledge". Otherwise, guru is generally accepted as "one who is regarded as having great knowledge, wisdom and authority in a certain area, and who uses it to guide others (teacher)". "Expert" on the other hand generally means "someone with extensive knowledge or ability based on research, experience or occupation and in a particular area". "Experts are often called in for advice on their respective subject, but they do not always agree on the particulars of a field of study." Case in point. You and I have had slight disagreements in the past as to the specific configuration of the production model of the Essex Tri-Directional. I still believe they were built in different configurations almost as if the factory simply released prototype versions for "realistic testing in the field by the farmers". I believe you are in general disagreement with that premise. Correct me if I'm mistaken. As always, Cheers.
