HF to-20, 3 point
Hello Lora welcome to YT. I replied to you by email with
some information that may be helpful. The email will
come to you from Postmaster at Yesterdaystractors. If
you have yahoo or hotmail check your spam folder it
may have placed it there.
There is a topic section here that focuses on Ferguson
tractors. If you do not get many replies here I would
suggest you repost this over there. The link will take
you there.
YT Ferguson topic section
The control valve is most likely stuck. With the engine off, open the ride side access cover and reach into the oil
and feel around for the T shaped stem of the control valve. the ends of the T should be in the H shaped control fork
ends. If you push the T shaped handle forward it should move easily about an inch total. Do the same in the backward
direction! There could e some dirt thats caught between the bore and the control rod, or the T shaped end is only
connected to on part of the H shaped control fork.
(quoted from post at 18:28:38 06/22/23) The control valve is most likely stuck. With the engine off, open the ride side access cover and reach into the oil
Please advise the OP in what direction to reach. Forward? backward? forward and slightly up????
