High speed rear ends
muleman51
I see some of you talk about high speed Oliver rear ends, what does that give you for a top speed. Do they make them for other tractors? How
about a Case 830ck?
I don't know about Making them for. The Oliver high speed rear ends were factory option.
I think it was actually the transmission that gives the higher speeds in 5th and 6th. But I'm no expert. My 1550 has high speed but has the lower ratio ring and pinion. It's a bit slower in 1 through 4 and really jumps in 5 and 6. 20+ on 16.9-38s.
Tractor pullers like the standard tread 88 ring and pinions but will kill for the 40 combine ones---Tee
If a 830 ring and pinion is the same as a 400 or 700 then a orchard or high crop will be 22% faster
The concrete blocks are in there weakest position with holes to the sides. As well as line contact on the flats that should have a board between. I know it won't get changed, but don't go under there. I had a principle killed where I was teaching form that very issue. Jim
(quoted from post at 02:55:29 06/07/21) The concrete blocks are in there weakest position with holes to the sides. As well as line contact on the flats that should have a board between. I know it won't get changed, but don't go under there. I had a principle killed where I was teaching form that very issue. Jim
A 1650 will go about 25. Made a great tractor to haul loads to town .
