Hiniker cab #1300
Dan(wi)
Just purchased 2 cabs the one in question is the Hiniker #1300, my question is the weight of it? If i had to guess it would be over 1000lbs, thanx Dan
Dan,
Some years ago my son and I installed a 1300 Hiniker on our Ford 9000. I'd sure guess that you are right about the weight. It is a very substancial ROPS tested cab. For install purposes, I'd take off the doors and rear window to shuck some weight. I hope you got the correct brackets to fit your tractor, as they are pretty heavy built also. Good Luck!!
Paul in MN
