hitachi cordless drill chuck replacement
jim_uny
have a hitachi DS14DvF3 drill with bad chuck. part is nla. bought a DS13dVF on ebay. like the newer model better. want to swap chuck. how do i do it ? got instructions or vid. not in owners manual.
Thank you for contacting Hitachi Power Tools,
Turn the sleeve of the Drill Chuck counterclockwise (when viewed from the front) to fully open the jaws of the Drill Chuck. You will see down inside the chuck a Special Screw (Left Hand Thread). Turn this screw clockwise to remove it. (Note that the special screw is left-hand threaded.) Insert the short end of the largest Allen wrench you have into the Drill Chuck and tighten the chuck on to it. Place the drill on the edge of the work bench with the chuck & wrench hanging off the edge of the bench. Turn the Allen wrench to the ten O?clock position and while firmly holding the drill down against the bench. Hit the Allen wrench firmly and quickly in a counter clockwise direction to break the chuck loose from the spindle and then just remove the chuck by turning it counter clockwise
Thank you,
Customer Service Representative
Hitachi Power Tools
Tanaka Outdoor Power Equipment
1111 Broadway Ave.
Braselton, GA 30517
P 800.706.7337
F 800.830.7593
www.hitachipowertools.com
www.tanakapowerequipment.com
dewalt drill chuck fix
