If I unbolt the swing draw bar clevis from the rear end, will it drain the rear end?
I need to remove the whole assembly. The PO welded a heavy bar from the clevis to the hang, and two from the sides of the hanger angled to the clevis, and welded a steel ring to the back of the hanger, with bolts going threw it, and the PTO shaft housing. I think the housing is under it.
So now it is all one really heavy solid piece. I don't know why he needed it so solid, but it is now!
But I want to remove it for cleaning & painting.
Also, how is the draw bar held in place from side to side. This one has a 3/8" bolt dropped in on each side just hanging threw the holes on each side.
Thanks, Pat
Thanks, Pat
