Hmm? New distributor
Olliejunkie
Void the warranty or dont use it
WHERE IS THE LAUGHY FACE BUTTON on here i need to push it. Who and where did you get that from?? , Call them up and tell them it does not work and you can't get the tractor to run.
Release the clips, gently tip the cap towards the seal strip, and get your rotor position. Then tip it back into its original position and refasten the clips.
Otherwise, call the manufacturer and ask them how to use it without voiding the warranty.
(quoted from post at 08:52:55 04/18/20)
Me thinks that's kind of like a tail light warranty.
I wont mention the seller but I did send them a note as to how am I supposed to install this. I will probably have it installed before he gets back to me. My guess is they put stickers on all electronics and they probably dont have a clue what it does. That's not the only sticker. I think they had a note that said the points where adjusted but installer may need to reset them. Lol.
(quoted from post at 12:29:16 04/18/20)
nce we are all done laughing, you have a 1 in 4 chance of getting it right on first guess and if not, then you will hit the gold on one of next 3 tries. Don't need to see inside.
(quoted from post at 09:35:30 04/18/20)
From my experience it is helpful to turn the rotor when installing. Guess I could turn the engine instead. It has a slotted oil pump so I should only be able to install it two ways. I have been tempted to turn the engine several times since I removed it but I have abstained so far.
(quoted from post at 12:51:31 04/18/20)
? more like a dozen, I say.
Ok. I went back and read it again and it states to disgard the stickers.
Guess I should've reread it first but it was fun while it lasted.
So now I guess I can tell you I got it from Cross Creek. So far they look good.
