Homemade quick attach for loader-pictures
Fred Werring
Location
Winchester, Ohio
Sure not claiming this was my idea, read about it on a forum somewhere. Decided I had more time than money, actually made a pretty good hourly rate fabbing this up as opposed to buying a pre-made one.
Leave the top pins in your attachment, go in and pick it up with your loader, put your bottom pins in and ready to go.
Used a hole saw and drill press for the holes. You can slow a drill press down enough that you don't burn up the hole saw, use plenty of cutting oil, got 26 holes through 1/2" steel with 1 hole saw.
Portaband saw for the cuts, and an old Sears buzz box welder.
No fair laughing at my welds, they're ugly, but have held for 6 years.
Used the measurements from my bucket to make the brackets, then adapted the hay spear to fit the brackets.
Be Good
Fred
That"s the same basic concept that my local welder used in the late 70s to make one for my reversed AC WD loader. My commercial Quik-tach on the 3020 FEL works a bit faster, but this works fine. Pointed pins go in quickly if the machine work is accurate, so holes line up when the bucket is raised a bit and rolled back.
I like your setup Fred. I have been looking at them, but don't care for the $500-up price tags. I always dread switching my spike and bucket, and often refuse to until I absolutely have to, then this week I needed the bucket to move snow, and had the spike on. It is still on, as I refused to wrestle it in the zero temps we had this week. Looks like a project after I gather some materials.
Had the same motivation..the Massey came with a deep 7 ft bucket on the loader, sucker weighs a ton.
Would almost rather take a whipping than put that bucket back on.
Fred
I figured you had that down pat, with the pads on the front of the unit- they buck up to the attachment, and hold it in the exact place for the holes to line up when the bucket is raised and rolled back- hits home position every time. Otherwise- simply not worth the effort to make one. Then, it"s BFH time, and that gets old. You took the time to do it right the first time, and the payoff is EVERYTIME you hook up.
