Southern Ray
If you have or have access to a hole hawg you can make a mighty respectable posthole auger.
This one consist of a discarded 7 1/4" circular saw blade bolted onto a 1/2" thread rod.
The tooth is cut with a cutoff wheel mounted on an angle grinder. It is then bent to shape.
The length of the point is determined by the soil condition. A longer point is needed for wet and mucky soil.
For damp sandy soil a shorter point will suffice.
It does have two side negatives.
It will not drill into hard pan soil. You will still need a regular posthole digger to bust through to damp earth.
The second is overcoming the urge to become too aggressive. It will dig! You still must pull it out of the hole with a load of dirt.
I dug the holes for these fence post in about 15 minutes each. The post are 8 footers set 46" into the ground.
