J. Brock
While doing a compression test on this gas 1973 175 I had left the ignition in the run position for a few minutes and I noticed the coil was kind of hot.Not like burn you hot but pretty warm. I had the coil wire-to-cap unplugged at cap. Is this normal.
It is normal if and only if the points were closed when you left the key on. Then the circuit between the battery and the coil through the points to ground was closed and there was a current through the primary ignition circuit of about 4 amps. Removing the wire from the tower on the coil, which is part of the secondary circuit, has nothing to do with the primary circuit in this condition.
