How Bad is my Timing (Making Hay)
TomNTex
I work in Kuwait on a month on month off rotation so my cutting and baling doesn't always go per plan. Seems I'm always a month late and dollar short on this hobby farm. I have about 30 acres (lake bottom black soil)of hybrid sudan (haygrazer) that was ready to cut during my last trip home. Long story short, it rained about 6 inches the morning I planned to start cutting. Some of the hay was standing in 8-10 inches of water. Three weeks later it was still too wet and time to go back to Kuwait. Now I'm back at work scheduled to go home in about 3 weeks. The standing water is gone and the surface is starting to dry out and now I have this 10 foot high jungle of hay. Not sure how much taller it could get in the next 3 weeks. Question is, can I still cut and roll this hay for the cows? I realize it is way past prime nutrition. Will my JD 1209 moco knock this stuff down.
Thanks,
Tom
I'd cut it cows don't need perfect hay and if the quality is a little down you can feed supplemental protein blocks.Proably it'll do fine.I cut hay all year cutting some now thats hasn't been cut so far and probably the cows will
do OK on it.I just give them all the hay they can eat all Winter
No one close around you to do your hay for you? Working in Kuwait flags me to believe that money is not a hardship . I certainly would look into finding a custom operator to take care of your haycrop and relieve some of the stress this is causing.JH
I planted about 10 acres of this stuff several years back. Due to a dry spell it took a while for most of the field to get to a decent cutting height. However the low area grew like gain busters and easily top'd ten foot (more like 12-14). The 1209 went through it with no problems. I just slowed down a tad. Bar will push it over but it will still cut it. Bad part is it will take so long to dry the stems it will look like crap. The areas where it was ten foot tall it looked like corn stalks when bales. But the cows still picked through it and ate what they could.
BTDT......had a 40 acre field a few years ago, rained 2 or 3 times a week for weeks and couldn't get it cut; baled 11 (1500#) bales per acre. Cut it with a Taruup flail-type disc mower conditioner.......1st and 2nd gear on a 4020. Your 1209 should handle it.......if you've got 'enough' tractor. Cows didn't eat EVERY bite, but they still pretty much cleaned it up.
I was sitting in my tractor at the field for a month waiting for a hay forecast, So you didn't miss much.
get it tested before you feed it to cows...i understand sudan gets prussic acid poisoning when stressed just like johnson grass...not sure if near drowning counts as stress but to me it aint worth the risk...testing is way cheaper than replacement cattle.
Some of my sorghum-sudangrass was pretty close to 10ft tall when I cut it a couple of weeks ago. Unfortunately, some of it was 5in tall because it had been lodged down by straight-line winds. It will still be fine to cut and I think the 1209 will cut it fine as long as you can keep it from plugging.
If you're not doing it already, I highly recommend using a wrapper and making balage out of it. I got a little worried last year that I had poisoned my cattle when I started feeding it out because the next morning most of the cows where laying down and groaning. It turns out that they just eat so much they were acting like me after Thanksgiving dinner.
Have used hay grazers and sudan grass for years, wet years it gets away from you, just more volume to bale. When planted at high population rates the stems remain fairly small even when 10-12 feet tall, the nutrients are in the leaves and young fast growing leaves are more digestible percentage wise than more mature leaves, the higher volume of the taller forage pretty much negates the nutritional percentage loss. Prussic acid is normally not a problem with sudans and hybrids unless grazing on new growth during or following a drouth, prussic acid, if present, dissipates while the hay is curing.
