How do I identify what distributor I have
smahler
I have a JD 3010 w/ a 201 engine and want to go electronic ignition. I am told it has a Delco distributor but I need to know the distributor model number before I can order the part set. I think its an 1112577 cause its a clip on cap, negative ground 12 volt distributor....How can I tell for sure, though? Any help would be greatly appreciated.
Thanks,
Shawn
See attached pictures...this is the distributor Shawn was asking about for me. JD says a Delco 1112363 or 1112474 is what should be in that tractor but I got a electronic ignition kit for that and the plate is too big. Diameter of inside of housing is 2-7/8". JD said it was probably replaced with some other dist...I did not see a plate but will look again. Aaagh!!! I will post pics when I get to a computer shortly...sending this from phone. Thanks for your response!
See attached pic
Lee...thanks for your help!! I found the tag on the back side of the distributor!! Scraped a little paint/ got a mirror and it is a Delco 1112577...Thanks again!
