How is this bleeder supposed to work?
Fritz Maurer
Took this out of my 02 F-150 front caliper. I thought it might be one of those spring-loaded one man bleeders I've been hearing about. The hole in the bottom lines up with the passage in the cylinder; I don't see how to close it when the bleeding is done. Whatever is inside that bleeder won't move, so I installed a conventional bleeder screw. What was the idea behind this thing? Thanks, Fritz
Any chance those calipers were replaced at some point? That looks like the threaded bushing rebuilders install when the threads are in poor shape. It allows the use of the next step smaller bleeder to save a caliper casting. I have had the bushings come out with the bleeder, I then go up a step in bleeder size.
I had this caliper off the truck and disassembled in my vise, because I had to heat the area around the bleeder to get it out. After I got the bleeder out, I could look right down the hole and see daylight at the other end. I didn't realize it before, but at the bottom of the hole there was a little chamfer that looked like it could have been a ball seat. It sure wasn't a bleeder seat, as the conventional bleeder wouldn't seal until I reached down there with a countersink and made a seat for it. I wish I had known that before, because I save steel balls whenever I see one, and I'm sure I have had one that would have worked.
Anything is possible, I didn't get the truck until 60,000 miles. I will take a closer look at it. If the bleeder was stuck in the bushing, where I heated the casting would have released the bushing from the casting so they both came out together...
(quoted from post at 07:05:13 05/18/19) Any chance those calipers were replaced at some point? That looks like the threaded bushing rebuilders install when the threads are in poor shape. It allows the use of the next step smaller bleeder to save a caliper casting. I have had the bushings come out with the bleeder, I then go up a step in bleeder size.
"That looks like the threaded bushing rebuilders install when the threads are in poor shape. "
I hadn't thought about that, Sprint6, but now that you mention it, I've seen that, as well.
I'll bet that's what it is!
(quoted from post at 13:04:43 05/18/19) sure looks like a heli coil to me that was put in and it unscrewed instead of the bleeder.
Never seen a helicoil with a virtually closed end on it.
I bet it is a "saver" bushing as mentioned.
If the bleeder can be removed from the bushing, the bushing has the proper sealing taper to match the bleeder.
