redoakroach
- Location
- Red Oak, Michigan
I've installed new liners and pistons in my tractor and the compression is low, 150psi. It's even across all four cylinders and will come up to 165 psi if I put oil in the cylinder. There is 8 - 10 pounds pull with a .0015 shim between the piston and sleeve. I have about 1 hour run time at this point. This is the 5th engine I've done and the first time I've had a problem. Should I be thinking about pulling it back down and honing the cylinders a little or just wait to see what happens after a couple hours of run time?
Larry
Larry
