How rare would this 9N be?
Winehead
Found what I believe to be a 9N sitting, looking rough in a field nearby. Serial number says 9N II50. Located owner and he wants $800 for it. One rear rim completely rusted through. No way to crank to see if it has cracked block or not - no belt, and some plug wires chewed through. Sheet metal actually in good shape, though steering wheel bent. Looks to be a 12V conversion. Any ideas where to start on making offer ifn I can't get 'er cranked? I can post pics later.
Wine
What does cranking and havening a crack block have to do with each other. If it has a crack block you can see it just by looking at it. Now as far as having bad rod bearing etc yea you need to get it started. In my area thats probably a $300-500 tractor tops and thats if the tires are in good shape
Hobby farm
Hey Winehead-
The early serial number makes it collectable, rare, questionable as there are many early 9Ns still around. The value is in the eye of the buyer---how much do you want to spend? Are you looking for a restore project? If you want it to restore, I'd be looking at what other original parts are still on it and in good shape. A rusted rim is a common problem and originals are around -again, what do you want to pay for original parts. If the block is not cracked but tractor has been setting a spell, I would drain all fluids before attempting to start. Search this topic in archives as there are many suggestions on bringing it back to life. Is the aluminum grille, hood maybe, dash, gauges; things like that still there? Do your homework if you want it. To each his own...
Tim Daley(MI)
*9N653I* & *8NI55I3*
Thanks for the info, I'm finishing an 8N refurb, not really a restore, although I've fixed or replaced most of everything on it, already have more $ in the refurb than what I paid for it. I'm starting a new thread with pictures of the 9N...
